I created a spline and wanted that to revolve arround the vertical Y axis.
The revolving happened without any problems, but I have three questions on that:
1.
After creating the 'revolved' body may I want to change the spline to modify the shape, so I moved the history back to the sketch where I created the spline, I modified the spline and moved the history back to the end.
But the revolved body does not update, it is still shaped using the first (old) version of the spline.
Is it not possible tho change the shape of the revolved body later on? Do I have to create it again?
2. Why the step of revolving does not appear in the history that I can edit it later on?
May this could help to recalculate the revolving if the spline changes.
3. How can I add an additional point ore remove a pint to an existing spline to change it's form?
Thanks for any help!
Solved by Macro.Liu_Autodesk. Go to Solution.
Hi thburn
I think the toll is “Roll”, as seen in the picture, after that I think it will refresh the respective features
Best Rishi
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
I think the roll wont solve the isseu, beucause the icon is simualer, the funcion is "Compute All" under "Modify"
Rishi Vadher
Personal Page
HI rishivadher,
I tried what you suggested, but without success :-(.
The button 'ComputeAll' does not do anything in my case.
As you can see in the attached image I first created a spline and used revolve tool to create the body (something like a plate).
Then I changed the spline's shape and pressed ComputeAll, but the body ist still the old one, the changed spline shape you can see also in the attached image.
What I am missing?
And I also still need some help on how to add / remove controll points to an existing spline.
Thanks!
Hi thburn, sorry for the delay on the answer
In this case can you make a new drawing just with one surface then move.
In this case is like there are some joints that constrain the sketch and can limit the movements of the feature our body.
Just run a test with a new clean project.
Best Rishi
Rishi Vadher
Personal Page
Hi thburn,
I don't know the exact workflow on your side, but I can try to answer your questions.
1. I assume you're working in Parametric environment (capture Design History).
2. So similar as above, if you choose to Create Form or Create BaseFeature first, all the features before you Finish won't be shown in Timeline.
3. You can easily to add/delete point to/from a spline.
Hope this can answer your concern. Please let us know if you still have any question.
Macro Liu
Fusion QA
