Is there a way to add a Symmetry constraint to Spline handles?
Right now I am laboriously dimensioning each handle.
See if you can repeat this problem.
If I -
dimension the aligned length of a spline handle and then try to dimension the angle (relative to a fully constrained construction line) - I cannot select the handle for dimensioning.
but, if I -
first dimension the angle, I can then dimension the aligned length.
Hi TheCADWhisperer,
Thanks for posting the issue and detail description. Unfortunatelly there is some issue about losing the selection for the spline handles if a dimension already created on it sometimes. Our developer team is looking into it.
We will keep you updated. Thanks again for your help.
Shirley
Developer for Fusion Electronics
