Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Snap between different sketches ?
2 REPLIES 2
cekuhnen
529 Views, 2 Replies
Is there a way while drawing in a new sketch to snap to curves of a different sketch?
I seem not being able to figure that out.
Claas
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
2 REPLIES 2
deyop
in reply to: cekuhnen
First, make sure you have the option for 3D sketching of lines and spline checked in the Fusion 360 section of General preferences.
Then include the 3D geometry (including other sketch elements) with the "Include 3D Geometry" within the sketch commands.
You will then be able to snap to those sketch curves.
cekuhnen
in reply to: deyop
Hi there
Thank you for the information.
Two things I observed:
Snapping to 3d geometry when drawing works well.
However snapping does not work when I move a curve point. Sketches, 3d geometry and also the grid are ignored.
I can also not snap draw a curve to a profile in a different sketch object.
Claas Kuhnen
