Here is a new failure mode I haven't come across before, and stopped my project in its tracks.
Drawing as simple sketch getting ready to extrude into 3d.
Adding just a new 2 point rectangle.
Entering 10 and 2 mm's as the constraints, everything looks good.
Then I press enter a couple of times to complete, and instead of a rectangle I get an error message as per
Maybe I am missing the obvious, but shorly there should not be a problem with adding a rectangle...
Solved by NicolasXu. Go to Solution.
Note that using a mouse click rather than return to commit the new rectangle worked fine, so at least I am working on.
Hi big_red_frog,
Thanks for reporting this issue.
It’s a problem that the development is looking into. And glad to know you have found a workaround. Hope we can improve this in future updates.
Recently, another user reports the similar case and you may want to check it for more information:
http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Fusion-360-update-bugs/td-p/4876674
Please keep the feedback coming!
Best Regards,
Thanks your post and detailed information!
The issue is reproducible. I checked it with Nicolas. Developer is working on the issue now. Sorry for inconvenience.
It's good to know you have workaround to continue your design.
Is it solved ? I'm using a mac version and i have the same problem. Clicking with the mouse doesn't solve anything for me. Am i doing it wrong ?
Hum after many others tries, it finally worked when i clicked with the mouse, but i can't find the correct process yet. Sometime i click left button and it doesn't work, sometimes it works...
Thanks, it works perfectly like this! The problem is just not to move the mouse while pressing the left click...
Hi all,
I just want to give a update that this issue has been solved in the latest update (June release build 2.0.1183). It works for either mouse click or Enter key.
Not fixed in fresh intall on 10\30\2014 version 2.0.1300
When I drag off the dimension I see it there in ligh grey but ENTER or LEFT CLICK just gives the error mentioned.
Hi peaboy,
Sorry to hear that you still experience similar problem. I double checked the original steps in build 2.0.1300, but not able to reproduce the error.
Did you see the problem in the same steps or is it a different scenario which leads to the warning? Could you add more details (file, screenshot & video, etc.) here so we can reproduce it? If it's a different scenario, it's recommended to report it in a new post for easy trakcing and searching.
You may use the Autodesk tool screencast for video recording: https://screencast.autodesk.com/
Thanks for reporting this out,
Thanks for the update, peaboy.
Please keep reaching out for any questions or problems you may encounter.
