Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sketch geometry is over constrained
19 REPLIES 19
Message 1 of 20
big_red_frog
2031 Views, 19 Replies
Here is a new failure mode I haven't come across before, and stopped my project in its tracks.
Drawing as simple sketch getting ready to extrude into 3d.
Adding just a new 2 point rectangle.
Entering 10 and 2 mm's as the constraints, everything looks good.
Then I press enter a couple of times to complete, and instead of a rectangle I get an error message as per
Maybe I am missing the obvious, but shorly there should not be a problem with adding a rectangle...
19 REPLIES 19
Message 2 of 20
big_red_frog
in reply to: big_red_frog
Note that using a mouse click rather than return to commit the new rectangle worked fine, so at least I am working on.
Message 3 of 20
NicolasXu
Hi big_red_frog,
Thanks for reporting this issue.
It’s a problem that the development is looking into. And glad to know you have found a workaround. Hope we can improve this in future updates.
Recently, another user reports the similar case and you may want to check it for more information:
http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Fusion-360-update-bugs/td-p/4876674
Please keep the feedback coming!
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 4 of 20
Thanks your post and detailed information!
The issue is reproducible. I checked it with Nicolas. Developer is working on the issue now. Sorry for inconvenience.
It's good to know you have workaround to continue your design.
Cathy Wang
Software Engineer
Fusion 360 Team
Autodesk, Inc.
Message 5 of 20
in reply to: Cathy.Wang_Autodesk
I have been fighting this issue as well. Driving me nuts.
Message 6 of 20
Helmi74
I had the same issue several times but didn't note that clicking the mouse could solve it. Will try it the next time it happens. Was driving me nuts already.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Message 7 of 20
rekom23
in reply to: Helmi74
Is it solved ? I'm using a mac version and i have the same problem. Clicking with the mouse doesn't solve anything for me. Am i doing it wrong ?
Message 8 of 20
Helmi74
in reply to: rekom23
no, it is just not solved.
Frank / @helmi
Message 9 of 20
rekom23
Hum after many others tries, it finally worked when i clicked with the mouse, but i can't find the correct process yet. Sometime i click left button and it doesn't work, sometimes it works... Robot LOL
Message 10 of 20
Helmi74
it should always work with the mouse button (at least it did for me so far) but the problem persists while pressing the enter key after entering some values.
Frank / @helmi
Message 11 of 20
rekom23
thanks for the infos!
Message 12 of 20
rekom23
So you "fix" the value (with the locker) also with the left click ?
Message 13 of 20
Helmi74
i use the tab key to jump from value to value and finalize with a left click instead of an hint on "enter" (which would bring up the error).
Frank / @helmi
Message 14 of 20
rekom23
Thanks, it works perfectly like this! The problem is just not to move the mouse while pressing the left click...
Message 15 of 20
Helmi74
yeah it's not more than an ugly workaround - i hope this bug will be fixed sometime soon. i already wondered why they couldn't fix it for the may update.
Frank / @helmi
Message 16 of 20
NicolasXu
Hi all,
I just want to give a update that this issue has been solved in the latest update (June release build 2.0.1183). It works for either mouse click or Enter key.
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Message 17 of 20
in reply to: NicolasXu
Not fixed in fresh intall on 10\30\2014 version 2.0.1300
When I drag off the dimension I see it there in ligh grey but ENTER or LEFT CLICK just gives the error mentioned.
Message 18 of 20
NicolasXu
Hi peaboy,
Sorry to hear that you still experience similar problem. I double checked the original steps in build 2.0.1300, but not able to reproduce the error.
Did you see the problem in the same steps or is it a different scenario which leads to the warning? Could you add more details (file, screenshot & video, etc.) here so we can reproduce it? If it's a different scenario, it's recommended to report it in a new post for easy trakcing and searching.
You may use the Autodesk tool screencast for video recording: https://screencast.autodesk.com/
Thanks for reporting this out,
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Message 19 of 20
Just wanted to let you no longer see this in the released version as of 12/11.
Thanks!
Message 20 of 20
NicolasXu
Thanks for the update, peaboy.
Please keep reaching out for any questions or problems you may encounter.
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
