Can I define the value of a dimension by a formula ? For example, the Arm (dimension) to be 70% of the Leg (dimension).
I can not find such information. If it is not possible, I will propose it as an enhancement candidate. Thank you.
Solved by TheCADWhisperer. Go to Solution.
Notice that I made one dimension a function of another simply by typing in the equation.
If you want to - you can rename the dimension variable names.
Here I named them Arm and Leg. Fusion replace the autoassigned d1 and d2 with the new variable names in the equation.
If you create your User Parameter variable names in advanced -- you can simply type them in as you go
