The red mark below show the area of interest. I defined a dimension (angle) between these 2 lines but it disapeared.
When I try to re-add the dimension again I receive an error message: already has same dimension on referenced geometry.
Is there any other way I can see the dimensions, constraints so I can fix this ? Thank you.
Solved by mbraga0001. Go to Solution.
Solved with information provided by TheCADWhisperer.
The Modify / Change Parameters is the "other way" to access the constrain parameters.
