How do I select a sketch inside of a body?
I do not get a select other tool?
After a bit more experimenting - it seems that I can window select the sketch. Not sure this is going to work in every situation (multiple profiles with design intent to select specific profiles).
If I enter Section Analysis - I can select the sketch and perform desired operation, but then how do I exit the Section Analyisis view?
OK, I figured this one out in the browser.
Looks to me like there should be a right mouse option to do this.
Maybe I haven't found it yet.
OK,
A bit more experimenting and I see that the selection behavior is different depending on whether I select Extrude from the Create tab or Press/Pull from the Modify tab.
Holding down the left mouse button over the sketch profile and a list will appear, which will allow you to select the sketch inside a body. Hope that helps.
