i updated to the latest version already but a weird behaviour that i have seen in the last version too keeps appearing here.
When closing Fusion i occassionally (well quite often) get the message that there's still data beeing uploaded and if i really want to quit. This also happens when there's no design open and of course no upload/import is going on.
Now after i got this message this morning after coming back to fusion after some hours i got the next weird error when opening fusion: It told me my design that i last worked on was changed by another user and i should check the details. It took about 5 minutes to load the version history where it showed me that the lastest version was updated 4 minutes ago from my user account.
I don't know how this happens and where it comes from but this is confusing.
The upload message appears independent from any special file so i didn't attach any.
Hi Frank,
Thanks for the post.
The confusion with the first issue you reported (with the dialog warning about pending uploads at exit) is probably because we don't show "all" file uploads that are happening. We only show uploads related to import and files created or edited in offline mode. This was done to limit the number of items showing up in the "Upload Progress" dropdown.
The second issue you mentioned appears to be a bug. We'll investigate it some more.
Thanks for reporting
Ahsan (Fusion Data Model)
Thanks for the comments Frank. Yes, the behavior is slightly different in the latest release. Earlier, we would simply wait until all the uploads completed. This could sometimes take a long time (depending on network speed or Cloud server load), and often made the user wonder if the process is hung. We'd heard that customers would often just kill the process. To avoid confusion, we added a message to warn the user that there are pending uploads. Granted, we need to make the experience a little better. We'll discuss this internally and see what can be done in the future releases.
The good news is that file upload performance has dramatically improved recently, so users should not see this warning dialog as often.
Ahsan
The quit behavior is frustrating. If I have it save on quit, or just save and then quit, it gives me the warning that uploads are in progress. I often cant see what's being uploaded, and I end up having to sit there and try quitting several times until I'm no longer warned. It seems that it should be able to give a progress dialog to prevent people from thinking it hung, then close upon completion. This would be REALLY nice.
