Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Renderer changing geometry?
1 REPLY 1
donsmac
224 Views, 1 Reply
The two images are the same view, one has the renderer on. There is no bump or relief on the texture. The geometry appears to change:
Here it looks good:
Here it's distorted when rendered:
Another view, looks ok here:
Here is the same view rendered, showing a change in some geometry:
Side profile, I hightlighted the fillet to show the surfaces clear each other, they don't intersect:
1 REPLY 1
joel.palioca
in reply to: donsmac
Hi Don,
Apologies for the delayed response.
Would you be able to send me the model so that I can take a look on my machine?  I have tried a couple things here and I can't reproduce it with the models I have, so having your model would be valuable in reproducing this for us.
You can upload the file to the forums or you can also email me directly and I can help from there.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
