The two images are the same view, one has the renderer on. There is no bump or relief on the texture. The geometry appears to change:
Here it looks good:
Here it's distorted when rendered:
Another view, looks ok here:
Here is the same view rendered, showing a change in some geometry:
Side profile, I hightlighted the fillet to show the surfaces clear each other, they don't intersect:
Hi Don,
Apologies for the delayed response.
Would you be able to send me the model so that I can take a look on my machine? I have tried a couple things here and I can't reproduce it with the models I have, so having your model would be valuable in reproducing this for us.
You can upload the file to the forums or you can also email me directly and I can help from there.
Cheers,
