Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem loading
1 REPLY 1
deanlegg
211 Views, 1 Reply
Problem loading
Had problems loading Fusion for the past few days
After signing in 5 times I got to my hub and then in the Recent Data box I have a spinning circle and Loading so far for 10 minutes
Any ideas?
1 REPLY 1
innovatenate
in reply to: deanlegg
Do you know if you've installed the latest update (Fusion 360 version 1.8.674)? This was released on Oct 14.
If so, did you recently install the update? Have you been working in offline mode at all?
I am not sure if the following suggestions are relevent to your system, but I'll throw them out there. Have you tried disabling Firewalls, anti-virus, or updating any proxy server setting in the preferences?
Have you submitted any crash error reports (CER's) that may be related to this?
Nathan Chandler
Principal Specialist
