Hello:
Perhaps I'm doing something incorrectly here, but press-pull is failing at times (at least on this iMac).
Please see the screencast: https://screencast.autodesk.com/Main/Details/22644bd2-fe9f-4ef9-a8c0-5f777c7da4a5
In summary: a similar boss exists. A linear pattern fails. So, try drawing from scratch -- sketch complete. Select press/pull and use the existing boss to pick out the same height -- which shows correctly in all dialogs. Accept=fail.
File attached.
Cheers, C
Solved by Cathy.Wang_Autodesk. Go to Solution.
Thank you for posting about this and I'm sorry we didn't reply sooner.
I reproduced the critical issues you mentioned. The root reason is some functions cannot work well on Inch unit with Fractional format (they worked when the input is bigger than "1"). I'm sorry about it.
If we change the Foot and inch display format to "Decimal". The problem will be gone.
I will transfer the issue to developers and they will fix the issue ASAP.
