I am in patch mode.
Two questions:
1. I want to create a flat face between the selected edges. How can I do that?
2. Is there any way to create a face between 4 selected vertices? - How?
Thanks!
Solved by jakefowler. Go to Solution.
Great questions! Hope these suggestions help:
1. Probably the best way to do this is using the Loft tool from the Patch workspace. Selecting one of these edges, followed by the other edge, should give you the surface you are after. If this doesn’t, let us know
2. There’s currently no way to create a face/surface like this based only from points. I’m guessing what you’re after is a 4-sided face which has straight edges connecting those 4 vertices? The easiest way to do this is probably to build some sketch lines connecting those points, then build a Patch or Loft surface based on those lines.
Does this seem like a feasible workflow? If not, the next thing we might need to do is to get some more detail about your input geometry & the result you are trying to achieve. If it’s possible to share the context for this workflow, that would be very interesting as well.
Many thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Hi Jake,
this is exactly what I needed. I also tried the loft tool by myself but could not get it working since all edges where selected as once.
This was because 'Enable chaining' was (is) enabled by default. If I disable it then I can choose two edges and use the loft tool to create the flat face that I needed.
Also the 2nd way you posted was very interesting to me and also this works and gives the same result.
Thanks a lot!
