Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
New add function parameter what expression can I use?
4 REPLIES 4
george
668 Views, 4 Replies
The new add function parameter, under expression, how can I use it, or can it use normal spreat sheet formula?
Where have the information about it?
4 REPLIES 4
rishivadher
in reply to: george
Hi George
You can use the parameters as like inventor, just can create realcioncion and the funcion of import. export. Is not yet haded, you submit it. to idiaa station.
george
in reply to: rishivadher
Hello rishivadher,
Thanks for your reply, but I have not used inventor before, so I do not know what is it, but at least I can find imformation from inventor now.
Mike.Zhang
in reply to: george
Hi George,
You can find the help about Parameters here:
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
Hope it helps.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
george
in reply to: Mike.Zhang
Thanks Mkie,
That's what I want, I have read this page so many times, but I did not notice it hide there.
