Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Move a projected sketch?
5 REPLIES 5
designeyeq
4201 Views, 5 Replies
Hello all,
I am trying to copy , move and rotate a projected sketchScreen Shot 2014-07-23 at 12.20.50 PM.png. The move command dosen't allow me to select the sketch, and the copy paste command allows a move, but it makes the curved splines straight.
What is the best way to move, scale, and rotate a centerline sketch to an offset plane?
5 REPLIES 5
innovatenate
in reply to: designeyeq
First you will need to right click on the projected sketch figures and select "Break." This will convert the sketch figures into regular sketch figures and "break" any relationship to other geometry. At this point, you should be able to move or rotate the sketch figures normally.
Let me know if this helps or if there are any other questions.
Nathan Chandler
Principal Specialist
kingson138
in reply to: innovatenate
Great tips!
Kingson
Using Apple computers
jiang.peng
The bug "curved splines straight" is already noticed and logged.
thank!
dtruong0131
If anyone's looking for an up-to-date answer:
When creating the projection, there is a toggle to have it linked to the original geometry. "Projection link".
This answer is relevant as of April 2020.
levleon13
in reply to: dtruong0131
THANKS!
