Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Modeling error when I try to Extend edge
16 REPLIES 16
Message 1 of 17
karthur1
626 Views, 16 Replies
Got another part thats giving me problems.  I am needing to extend the edge shown here 1.75mm.  I need to do both sides of the surface.
When I try to extend the face, I get a modeling error.  How do I handle this?
I will end up with a 6mm wide rib that I will then extend down to the face that below it.  I just have to make it wider first.
The file is over the 1.5 MB allowed so I had to upload my file to here.  Sorry for the inconvenience.
Kirk
16 REPLIES 16
Message 2 of 17
innovatenate
in reply to: karthur1
Kirk,
I notice that the entire edge appears to be selected in both the screenshots. I was wondering if splitting the offset surface body into smaller sections might allow you to extend in "one direction" at a time (if that makes any sense). Later, once the extend is complete, you may be able to combine the surface bodies back together. Just a wild guess...
Hope this helps.
Nathan Chandler
Principal Specialist
Message 3 of 17
karthur1
Nathan,
I don't have the file with me. You should br able to download it. I put a lhyperink in my post.
I was trying to offset the entire edge. If I do it in small steps it leaves gaps in the surface. Not sure how to correct those gaps.
Kirk
Message 4 of 17
innovatenate
Kirk,
Sorry, I read right over top of the download hyperlink. I have the file now and am currently investigating this. The body in my file looks a bit different than the one in the screenshot, but it may be due to the angle of the screenshot. What was the surface body originally offset from in Fusion 360? I was wondering if it had any vertical faces....
Nathan Chandler
Message 5 of 17
karthur1
Nathan,
My customer gave me his model a neutral file. I imported this into Inventor. From there, I imported it into Fusion. I know that I could have gone directly from his model to fusion, but I needed to bring it into inventor to get this in the correct position.
Message 6 of 17
karthur1
Nate,
Did you look at this anymore?  I tried offsetting the faces individually and that seemed to work.  I cant figure out how to make the top of the new faces follow the countour of the upper surface.  The problem is very noticable in the corners.
Message 7 of 17
innovatenate
Kirk,
My strategy so far has been similar to your approach. I did a 'Perpendicular' Extend first. Next, I tried to offset surfaces from the perpendicular faces. Last, I was going to patch between the two offset surfaces, but I bumped into the same road block as you. The offset surfaces weren't panning out. I'll forward the file to development with the original issue that the extent fails with an error message. There appears to be some limitation, but I'm not sure that I fully understand it well enough to make an intelligent comment about why. I apologize for not having better news to share at this time. 😞
Nathan Chandler
Message 8 of 17
innovatenate
in reply to: innovatenate
Kirk,
I was jus noticing that the body in that second screenshot is different from the file I have. There is a solid "lip" instead of only a surface. Could you share that file as well? Hopefully, I can work something out with that file.
Thanks for baring with me.
Nathan Chandler
Message 9 of 17
karthur1
Nate,
Here is the "latest" version that I am working with. This file is "F3462-P42K-BUL-451-V11.f3d".
http://we.tl/mvsbuMAJPt
Kirk
Message 10 of 17
karthur1
Nate,
There has been a design change.  Now instead of going 1.75mm to the outside and 1.75mm toward the inside, the outer wall of the rib needs to be offset 1mm out and the inside wall needs to go 2.5mm toward the inside.
Sorry for the late change, butI just learned of it.
Message 11 of 17
schneik-adsk
Still need some help on this? I'll take a look now and post something, but updates on if you found a solution yourself.
Kevin Schneider
Message 12 of 17
karthur1
in reply to: schneik-adsk
I am back to trying to do this in Inventor, but still having trouble, especially in the corners.  I was hoping that Fusion would handle extending the sides better than Inventor.
If you know of an "easy" method to do this, I would like to see it, but otherwise, I am trying a different approach right now.
Message 13 of 17
rishivadher
Alias,
but the workflow is not as intuitive has Inventor our Fusion.
Message 14 of 17
schneik-adsk
here is my best attempt.
https://www.dropbox.com/s/5t0rxx95jkb8p5d/Attempt1.f3d
Kevin Schneider
Message 15 of 17
karthur1
Kevin,
I couldnt get the link to work.
Message 16 of 17
schneik-adsk
Message 17 of 17
schneik-adsk
new link work?
Kevin Schneider
