Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Modeling Error - Kernel Operation Failed
14 REPLIES 14
Message 1 of 15
karthur1
1154 Views, 14 Replies
Is there anyway to patch this surface so I can get a solid?
14 REPLIES 14
Message 2 of 15
karyeka
in reply to: karthur1
Can you attach the model (surface)?
Anand Karyekar
Fusion360 Development
Anand Karyekar
Forge Graphics
Message 3 of 15
karthur1
in reply to: karyeka
Anand,
I am actually using Inventor Fusion.  Not sure if Fusion 360 will give this error or not.  If it works with Fusion 360, please let me know.
I uploaded the file to here.  There is an image in the zip there that will help you locate the surface.
Kirk
Message 4 of 15
karyeka
Hi Kirk,
I opened your file in Inventor Fusion but I am unable to locate the exact loop that you are trying to patch. I rotated the model to exactly match your image but looks like the model is different. The browser structure (number of quilts, unstitched surfaces, etc) is different.
Can you create a new group of the surfaces that are involved in your Patch operation and upload the updated file? Another option could be to just isolate the participating surfaces into a new file.
That way I could reproduce it at my end (and also in Fusion 360).
Anand Karyekar
Anand Karyekar
Forge Graphics
Message 5 of 15
karthur1
Anand,
Sorry for the confusion. I just downloaded the file and I see the same tree, however, Body 3 is active and Body 1 is suppressed.  The surface that is giving the error is under Body1.
In order to get to the unstitchable surface, toggle off the visibility of Body3, toggle on the visibility of Body. Expand Surfaces, and toggle on DefaultGroup:4
The surface is here...
Message 6 of 15
lure23
If this is for the Inventor Fusion, could someone at Autodesk move it to the right forum. Thanks.
Asko Kauppi
IT guy into Cleantech.
Message 7 of 15
karyeka
in reply to: lure23
This problem shows up in Fusion 360 as well.
Kirk, we have logged this as defect FUS-8134 internally. However, the model has errors. Can you elaborate on how you created or imported the model? Geometrically it is tolerant and seems to have issues. Lot of operations will struggle on such a model.
Anand Karyekar
Anand Karyekar
Forge Graphics
Message 8 of 15
karyeka
in reply to: lure23
Kirk, we have logged this as defect FUS-8134 internally. However, the model has errors. Can you elaborate on how you created or imported the model? Geometrically it is tolerant and seems to have issues. Lot of operations may struggle on such a model.
Anand Karyekar
Anand Karyekar
Forge Graphics
Message 9 of 15
karthur1
Anand,
This model was imported from a .stp file. I first brought this into Inventor 2013.  When I imported it in, Inventor found several errors as well. After and exhaustive effort, I gave up on healing the errors using Inventor.  I thought that I could bring this model into Fusion and using the tools there to heal the errors.  I then planned on exporting the healed model back to Inventor.
Kirk
Message 10 of 15
schneik-adsk
Here is a link to a sat file:
https://www.dropbox.com/s/uhcwmarkslaiglc/120424.sat
Let me know once you have it as I will take the link down.  The geometry is messy as it has been healed too often. If you have the very original source file I might be able to get you a better version.
I used Fusion 360 to create some new patches, extended some ajacent faces and trimmed back some slivers to get it all to stitch. The patch is fugly but it makes a solid.
Kevin Schneider
Message 11 of 15
karthur1
in reply to: schneik-adsk
Kevin,
I opened your file in Inventor 2013.  It shows two areas of "Loop Orientation" issues when I open the file.  The issues are in this area.  Are there any tricks to correcting this type of issue?
Thanks for "Fixing" the other area.
Kirk
Message 12 of 15
schneik-adsk
let me have a look over the weekend.
Kevin Schneider
Message 13 of 15
jakefowler
Hi Kirk,
Are you able to share the STEP file that you originally imported into Inventor? It's possible that these issues were introduced somewhere along the translation process, and with the original STEP we should be able to diagnose that.
Many thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Message 14 of 15
karthur1
in reply to: jakefowler
Sure.  Its too large to post here, but I can send it to you directly.
Message 15 of 15
jakefowler
Hi Kirk,
That's great, many thanks! Please email it to jake[dot]fowler[at]autodesk[dot]com, and we'll take a look. (If that doesn't work, let me know and we can figure out a different transfer method.)
Jake
Jake Fowler
Fusion 360
