now the thing happened that always frightened me with a cloud based software service: I'm missing a quite important design. The project where it was in is still there - also some files with stuff that i have exported from that one design but that certain design looks to be completely gone. I've searched all my projects and did an overall search - nothing.
Is there any history for deleted files - i'm quite sure i did not delete this but i don't want to blame anyone else before i know it for sure.
Thanks for helping,
Frank
Have you had any luck locating the design? Did you try using the Filters in the General search?
There isn't a recycle bin in the dashboard that I'm aware; however, you should receive a confirmation if a design is going to be deleted.
Let me know if I can help.
Hi Frank,
Did these deleted design(s), ever show up on the dashboard as items? If so, we can surely retrieve them for you.
Did you work in it long enough to create multiple versions of the same design?
We could do a screen sharing and look for the design on the dashboard or in the upload queue that we maintain on the disk. Drop me an email at smoghe AT autodesk DOT com.
Thanks!
Shrirang
Fusion 360 Architect
I'll add. Please help us try and determine what Happened. If you can share the name and dates that you think something happened it will really help.
I have over 2000 design I have worked on for the last two years. I have never had a design go missing. We have no know cases of an item going missing so this is very important to us to determine what happened.
