Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Loft Command Missing??
4 REPLIES 4
752 Views, 4 Replies
Trying to locate the loft Command in Fusion 360.
Not under Create or Modify?
4 REPLIES 4
TheCADWhisperer
It is not yet supported in the history based modeling environment.
Turn off the history recording and you should have access to Loft (right click on the top node of the browser).
This thread demonstrates a couple of Lofted features.
http://forums.autodesk.com/t5/Help-and-Support/Is-a-3D-Sketch-possible-in-Fusion/td-p/5096368
Awesome! Thanks so much
schneik-adsk
A less drastic method is to insert a base feature and do a loft in the base feature the combine the result into your model.
Kevin Schneider
sculptn
in reply to: TheCADWhisperer
I was wondering if you might have an update as to when the various surfacing commands (sweep, revovle, extrude etc) might be supported in the history environment? I can only seem to activate them still with history off.
