I would like to measure the volume of a body in order to figure out what its mass would be. Is that easily possible in Fusion 360?
Hi You can get those properties by right clicking on the root component at the browser and select properties: Two screen shots to show you here:
Hi I deleted the last post because I would like to add a few more points. Yours is a great question! I used "Mass" from Properties to estimate the approximate cost of materials to be used in the actual model. Most of our projects will be made by Plastic Injection Molding method and the approximate Mass is quite important. To get the X, Y, Z dimensions I would save an STL file of the model and use a 3rd party 3D reader to get the dimension information. When 2D drawing is available for Mac Fusion users we should be able to get the dimensions within Fusion.
Just wanted to check on if the volume/mass calculation is available for Mac yet? Having some trouble locating ...
Thank you
Hi thanks for posting to the forum.
The properties for your parts are found by right clicking on the component node in the browser. Use "properties". It's the same for Mac or Windows.
I design a Steel parts over 100 kg, density is 7.8 kg / m^3, how to change density 0.0078 g / mm^3 to 7.8 kg/ m^3?
Your calculation is exactly the same, just divide your answer by 1,000,000.
Brett.
@BrettClausen wrote:Hi,
Brett.
Thank you your help. But this not my want, we need to know some casting parts over 1000 kg, the density g/mm^3 can't fit our request.
Brett.
Sorry, I think I may have misunderstood your question.
What are you trying to do?
Brett.
Try this.
1m^3 = 1,000,000,000mm^3
The specific gravity of steel = 7.85
The formula for a piece of steel in kilograms is - ((volume in mm^3) x 7.85) / 1,000,000)
The mass of a cubic meter of steel is 7,850kg - I.E. 7850kg/m^3
The formula for a piece of steel in grams is - ((volume in mm^3) x 7.85) / 1,000)
The mass of a cubic millimetre of steel is 0.00785g - I.E. 0.00785g/mm^3
To get the weight of any other material - substitute the specific gravity of that material for the number 7.85 in the calculations above.
Does this solve your problem?
Brett
Thank you for your reply.
thank you.
@BrettClausen wrote:Try this.
Brett
I posted this video on the topic recently: https://www.youtube.com/watch?v=TikstpkcRuI
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
How check the density/mass of the part in the mobile app. Is it possible I haven't found any info about this or is the mobil app only a viewer program that can't measure mass?
