I suspect there's a very simple answer to this, but I'm buggered if I can find it. Once you've used the Inspect tools (section analysis, curvature, zebra stripes etc), how in the name of all that's holy, do you turn them off again?
Cheers!
Solved by deyop. Go to Solution.
Once an analysis function has been applied a node is created in the Analysis folder in the Browser. You can make them visible/invisible from there as well as edit the selection input, settings or delete them.
