I tried importing a huge (100MB) solidworks assembly into Fusion360, just to see if it would work.....it did not, as the "import in progress" message is now continually in my dashboard for a few eeks now. Is there any way to just clear out that pending import...I have no need of the actual data, I just wanted to see if it would open...now I just want a clean progress indicator 🙂
Thanks!
Nick Kloski
Solved by joel.palioca. Go to Solution.
Can you share the SW assembly with me? I would like to test importing this into my workspace to make sure the problem is not on our end. I can send you an FTP location. Email me at andrew.sears@autodesk.com and I will send you the upload link.
Also, the information left over in the Progress panel can be removed by deleting the PLMCache folder for the lasted build.
Here is the location on my folder. C:\Users\USERNAME\AppData\Local\Autodesk\Autodesk Fusion 360\BUILD\PLM360Cache
Let me know if this does not help.
Andy
Oops....actually, deleting that folder helped for a few days, but now I see that hung job still in my queue! Any other way to get rid of it?
Nick Kloski
Did you attempt to import the file again and it got stuck again or did it just appear on your machine again after a few days?
Cheers,
Nick Kloski
Hi Nick,
Make sure you don't have any other uploads in the queue for Autodesk 360 products when doing this, we want to make sure that we don't mess them up as well 🙂
Browse to %localappdata%\autodesk\production and delete the JobManager360 folder inside of the production folder.
Please let me know if you run into any other issues,
