I'm trying to import a .svg file containing text into Fusion 360. When I do it, nothing is imported - no new sketch, and nothing on screen. I've tried creating .svg files using Illustrator and Inkscape, and neither are working. When I open the .svg files in a web browser I can see the text. I tried downloading .svg files online, and these import okay, so it seems like some setting I have wrong when saving my .svg files? I'm unable to attach the SVG files as the file type isn't supported for these message boards.
Solved by AutoDebilitator. Go to Solution.
Can you compress the files (Illustrator and Inkscape) with 7z or Windows zip utility? If not, can you email the file to me? Send to andrew.sears@autodesk.com.
Andy
I am new to F360 and am having an impossible time trying to import SVG.
After looking around the dark corners of the internet, I have found a few bread crumbs on the tactics used to coax the little vectors into F360.
The computer I am using is a MBPr and running Mavericks with Fusion360 v1.8.568.
I did find some directions that indicated that to import SVG files that you needed to be in an 'active' sketch. Which I did, and still the 'Import SVG' menu command does not appear.
Any help with this would be greatly appreciated.
