Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to update model to current version in an assembly
5 REPLIES 5
prcdslnc13
1387 Views, 5 Replies
Im modeling a large assembly (>100 parts) so I have been working the parts for my assembly out side of the "assembly" design to make them a bit easier to manage. It has been working great but as I work and find changes that need to be made, I am having uses updating the part in the "assembly" to the current version of the part file without completely deleting and replacing it.
I feel like I am doing something wrong and maybe missing a function. Can someone please help? Im used ot working in Creo and this is my first jaunt into 360.
5 REPLIES 5
jinhai.zhu
in reply to: prcdslnc13
Hi prcdsInc13,
Thank you for bring out this issue after using Fusion 360. Currently, we don't support updating models in assembly. And there is a same idea post in linked cad files on IdeaStation. We are considering this suggestion which is posted by you.
thanks,
Gavin
prcdslnc13
in reply to: jinhai.zhu
I feel like this is a feature that is absolutly needed for Fusion 360. The nature of the program, both with the colloaboration and the project file setup makes this a natural feature that should have been there from the start. This is a program that is on its way to being a solid software solution now that the history bar has been added. That still needs work but the ability to link models and update to their current version is extremely important.
I ran into the same problem!  I would also like to see some way to update your "assembly" design when changes are made to your "component" design files.
dcrouch9
Add me to the list too. This is a feature that is very much needed.
CGPM
in reply to: dcrouch9
Even bigger issue if you are going to machine the parts after designing them.  Can't wait for assemblies to be "fully" supported.  Still love the program though!!!
