Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to model a topo map
7 REPLIES 7
Message 1 of 8
sprior913
3034 Views, 7 Replies
My house is on a bit of a hill and as it happens I have a site survey map which has elevation lines and I think it would be cool to model the hill and my house so I could goof around with it and maybe 3D print it.
I think I know how to create a 2D sketch using the image of the survey map as a guide.  What I'm not sure how to do is to use the contour lines in that sketch to create a 3D body.  Can anyone suggest an approach?
7 REPLIES 7
Message 2 of 8
Oceanconcepts
in reply to: sprior913
I can't say that I know, but I would create a series of sketches, one for each contour, offsetting each sketch by the elevation. Then try using those as inputs to a loft in the Patch workspace to generate a surface. If you need a solid, you could use that surface to trim a solid block.
- Ron
Mostly Mac- currently M1 MacBook Pro
Message 3 of 8
ururk
in reply to: Oceanconcepts
(I know this is an old post, but it seemed more appropriate to respond to this thread, rather than create a new one)
I'm trying to do what sprior913 is doing, but to help visualize placement of a barn.
I created svg files for each elevation, and inserted them into construction planes spaced at 2' intervals. I tried lofting between the elevations, but keep getting this message when trying to loft between certain sketches:
Error: Tool body creation failed
Error: The loft would flow in an invalid direction.
Try adjusting the continuity settings. If two adjacent profiles are on the same plane, try moving one of these.
I then extruded all the elevations downwards to form one giant solid, and tried chamfering, but that too fails.
Any thoughts?
Message 4 of 8
prainsberry
in reply to: ururk
Would you be willing to post the model?
Patrick Rainsberry
Developer Advocate, Fusion 360
Message 5 of 8
Oceanconcepts
in reply to: ururk
Are you creating sketches on the construction planes, drawing the contours with splines, and using the splines to create a loft? It would help to see a screen shot or a sample file to visualize what you are doing.
- Ron
Message 6 of 8
ole.ersson
I am trying to do the same thing: I have a site plan modeled in AutoCAD with 10" polyline contours. I imported this "contour test.dwg" file into Fusion 360, creating a contour sketch, then extruded the contours to their appropriate heights.
Now I wish to smooth out the topography by eliminating the abrupt edges.
First I tried filleting and chamfering the edges but I could only get these actions to complete at their at the first and last line segments of the polylines. Edges in the middle of the Polylines would not work.
I also tried using the polylines as inputs for a Loft command. That also did not work.
It was suggested there is a way to do this using Forms. Apparently there is a way to mold a flat form to another shape.
I'd really appreciate it if someone can share how to do this!
I'm attaching the following files:
contour test.dwg
Tide Ave v2.F3z
Screen shot:
Contour test Fusion image
Message 7 of 8
Warmingup1953
Is the vertical scale correct in the screen capture?
Message 8 of 8
ole.ersson
in reply to: Warmingup1953
Yes. the vertical scale is correct.
The units of both the Autocad and Fusion files are inches.
I just attached another screenshot.
This shows the front line segment #1 to be 86"/
The height of the contours is 10".
I hope this answers your question.
Thanks for helping!
