I want to create a plastic bottle with a screw-cap and send to a 3D printing service.
Here my questions:
1. How to create the outer thread of the bottle?
2. How to create the inner thread of the cap that matches to the outher thread of the bottle?
3. If I create the outer thread of the bottle and use boolean operation to create the inner one of the cap then both threads have exact same size.
So I believe it would not be possible to screw the cap because it is to tight. How to make the thread of the cap a littlebit bigger (or the one of the bottle smaller) that there is some space for easy screwing?
Thanks for any help!
Hi
is something similer to this pic
i modelled it on "model" mode
best
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
thanks for reply. I am not experienced in creating a file for 3D printing.
Is the thread command suitable for creating a thread for bottle / cap? Are these thread types not made for threads made of metal like skews etc.?
Since the thread comman creates all kinds of thread types I wonder if they will fit together after 3d printing? Using these kind of threads I am not able to make the cap thread a littlebit bigger if it is too tight.
From my personal view the coil command my suits better because I can make any type of coil and even make the coil for the cam 0.1 mm bigger or smaller to get a smooth screwing.
Is someone here who can share experiences with threads / coils and 3D printing?
The thread command does not create the threadform for a plastic bottle.
If you cannot use one of the Section profiles in the Coil command - it might be difficult.
We 3D print a lot of parts - leave a little extra clearance between mating threads as the 3D printing process isn't very precise (depending on machine).
Attach your file here and I will take look and give my opinion.
Hi TheCADWhisperer,
thanks for reply.
Up to know I don't have any file since I don't know how to create the thread.
The profiles of the coil command are very few, so I don't think that one of them fits.
I think creating a sketch as profile and use the sweep command can sove this problem? But how to create a sketch/path like a coil/spiral?
I also do not know how the thread of bottle / cap must be to get a smooth skrewing.
How many turns I need, what is the best profile?
