Hello all:
. . . as part of the raft of issues I'm experiancing in the Mac side of things, the hole feature has started failing.
See the screencast: https://screencast.autodesk.com/Main/Details/1c021917-1550-4b70-bd7a-f0ada24a8c24
Steps:
+ couple of bodies modelled
+ select "hole"
+ choose face
+ center hole on existing circular feature
+ make sure preview is showing as-expected -- yes.
+ type in hole diameter
+ preview still good? Yes.
+ accept "OK"
+ failure.
Note:
+ computer peripherals wired or USB
+ bluetooth peripherals off/ OSX bluetooth drivers turned off
+ spacemouse driver turned off and uninstalled
+ fusion360 reinstalled
+ computer restarted
+ no other major apps running
File attached.
Cheers, C
Solved by Cathy.Wang_Autodesk. Go to Solution.
Thank you for posting about this and I'm sorry we didn't reply sooner.
It the same problem as your another post about PressPull. The root reason is some functions cannot work well on Inch unit with Fractional format (they worked when the input is bigger than "1"). I'm sorry about it.
If we change the Foot and inch display format to "Decimal". The problem will be gone.
I will transfer the issue to developers and they will fix the issue ASAP.
Thanks to posting them, Colin!
We will fix them as soon as possible.
