I just tried to install Fusion 360 on my Mac but it crashes at start up:
I tried to clean reinstall without success. Any suggestion?
Process: Autodesk Fusion 360 [2130]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier: com.autodesk.Autodesk Fusion 360
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [169]
Responsible: Autodesk Fusion 360 [2130]
User ID: 501
Date/Time: 2014-08-17 22:13:31.720 -0500
OS Version: Mac OS X 10.9.4 (13E28)
Report Version: 11
Anonymous UUID: D38954CC-E438-02F0-0BB9-37DE4AA4617D
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Qt.framework/QtCore.framework/Versions/Current/QtCore
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Reason: image not found
Binary Images:
0x7fff6397f000 - 0x7fff639b2817 dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
Model: MacBookPro6,1, BootROM MBP61.0057.B0F, 2 processors, Intel Core i5, 2.53 GHz, 4 GB, SMC 1.57f18
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x802C, 0x384A53463235363634485A2D314731443120
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x802C, 0x384A53463235363634485A2D314731443120
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.6f1 14216, 3 services, 23 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Hitachi HTS545050B9SA02, 500.11 GB
Serial ATA Device: MAT****ADVD-R UJ-898
USB Device: Hub
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Hub
USB Device: Built-in iSight
USB Device: IR Receiver
Thunderbolt Bus:
Are you submitting any of the error reports?
Thanks, I am not getting that error screen. I am geting OSX's one which reports to Apple:
http://support.apple.com/kb/ht1528
Let me know if you have any questions or if any of the above suggestions help.
