In the preview the fillet works when accepting the value it states tha value is to big.
https://drive.google.com/file/d/0Byzv_NlyKp_2V1RobW8wbXNCenM/edit?usp=sharing
However in Rhino the 1 cm radius works. So I guess there must be some sort of bug in Fusion here.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Hi cekuhnen,
Thanks for letting us know the problem. Would it be possible to send the file to us for a deeper look?
You can Export Archive from the 3 bar menu on the top left corner of Fusion 360. If you do not want to post the file to the community, you can send the file to me at lixiong.xu[AT]autodesk.com and I will take a look at it.
Best Regards,
Send you an email.
Claas Kuhnen
Thanks for the quick response, cekuhnen.
I can reproduce this issue. I will report the case into the internal issue tracking system and ask the development team to look into it.
Sorry for any inconvenience.
Hi Kingson,
Thanks for letting us know your case. We’re actively working on improving the product. Please continue to report any problems you encountered. These reports would give us the opportunity to improve the product and provide you with the best solution.
Best Regards and much appreciated!
Hi Claas,
I looked into this with Nicolas, and this does seem to be a quirk with parametric Fillet. As you can see from the successful preview, we're technically able to generate the geometry, but it gets blocked when completing the command.
A couple of workarounds that might help:
We're going to be working hard on improving the stability of the parametric environment over the next few updates, so please do continue to let us know when you find issues such as this.
Many thanks for reporting this, and hope this helps for now,
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Hi Jake,
sure will do to let you know in case something bugs.
This is a pretty impressive fast development you guys did sofar considering how many features were added compared to how long other applications take to grow.
At least in the direct modeling all works fine so thats good limiting this to the design time line only.
Claas Kuhnen
