Finally found some time to take a look at Fusion 360.
Top image shows what I want cylinders taper all in same direction.
But I had to try multiple times to get this to work.
More often, some would taper in one direction and others in the opposite.
I tried to be very careful to pick at the rotation "hinge", but couldn't find consistent results.
What is the trick?
Can you attach the file to this thread? I can't reproduce this so your model will help us figure out what is going on.
thanks,
Andy
Here is the file. (I think. This is the first time I tried getting it local.)
Is there any resolution to this? I'm having similar problems with draft.
I have just followed up with this issue and it looks like we haven't resolved this issue. I have pushed the team to see about getting this fixed.
Once we have a fix and it is ready for one of our updates, I will add a note to this post.
