Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Extruding multiple faces at the same time
1 REPLY 1
siddhardha.mjm
3040 Views, 1 Reply
Hello everyone ,
Is it possible to extrude multiple faces of cube to the same height by holding alt key
i have attached the image which i wanted to acheive done using polygon modeling
Need help
1 REPLY 1
I'm assuming you are in the model workspace. If you want to match the height of one face to another, and if the faces are co-planar, all you need to do is to start dragging with the push-pull  or the extrude tool and then click on the face you want to match.
You can also select multiple faces for a push-pull/ extrude operation.
- Ron
Mostly Mac- currently M1 MacBook Pro
