Hello everyone ,
Is it possible to extrude multiple faces of cube to the same height by holding alt key
i have attached the image which i wanted to acheive done using polygon modeling
Need help
I'm assuming you are in the model workspace. If you want to match the height of one face to another, and if the faces are co-planar, all you need to do is to start dragging with the push-pull or the extrude tool and then click on the face you want to match.
You can also select multiple faces for a push-pull/ extrude operation.
