This forum exhibits different behavior than some of the other Autodesk Community forums.
Why can I not embed a Chronicle here?
Hello @TheCADWhisperer!
Embedding a Chronicle is different than embedding a YouTube video in that it requires the use of the HTML tab vs. the post toolbar.
Clicking on the embed button on the Chronicle page will present you with the necessary code which you can then insert into a post HTML tab.
This code is what I used for embedding the Chronicle:
<iframe width="640" height="400" src="https://chronicle.autodesk.com/Embed/19fcb5a9-cebf-44ab-86f4-c0eda0617999" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Hi JD,
I moved this to a new thread so other users can find the information better.
Thanks for bringing this up!
Andy
@philip.s wrote:Hello @TheCADWhisperer!
Embedding a Chronicle is different ..
Here is what I get in IE (Note: no cursor to paste the HTML)
I can embed Chronicles in other Autodesk Communities here with IE just fine.
I can embed Chornicles here in this forum using Chrome just fine.
This community forum does not exhibit the same IE behavior as other Autodesk Community forums.
(I already indicated that I cannot attach *.f3d files with IE (haven't checked again since posting).)
