Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Editing holes on OSX crashes
3 REPLIES 3
LeonMF
455 Views, 3 Replies
I have a Macbook Pro Retina and any time I edit a hole, the application crashes.  I can edit the same hole on my work PC, though.
I've attached the file. (Don't laugh at my crude cad skills, I'm still learning 🙂 )
Tags (4)
3 REPLIES 3
innovatenate
in reply to: LeonMF
Are you right clicking on Hole 28 in the browser and selected Edit Hole? I can do it on both my mac mini (OS X 10.8.3) and on my PC without receiving an error. Are these the steps are you following?
Nathan Chandler
Principal Specialist
LeonMF
in reply to: innovatenate
Yes.  However, that hole is post-edit on the PC.  I'll check it on my mac when I get home.
If it works and I can make the crash happen with a pre-hole edit version, I'll post the crashy version.
LeonMF
in reply to: LeonMF
If I can reproduce the problem, I will repost here. Right now, I can't make the crash happen. Last night, I couldn't edit a hole without crash. Maybe the reboot I did this morning solved it.
