Greetings,
I need to export several of my designs as dwg's so an associate can use them. I've exported them from the data boxes as dwgs and then downloaded them after the upadate message shows up on my home page.
The problem is that they show up as blank when opened in Autocad. We've tried 2004 and 2014. We've also tried importing them into Solidworks but get the same result.
Oddly, if we re-import them back into F360, they open up fine.
Thoughts?
Hanswurst
Hi Hanswurst,
I just imported a DWG file into AutoCAD 2014, and after initially the screen came up blank, but after I hit the home button the graphics window resized and my model showed up correctly. Are you not seeing the same thing?
If not would you be willing to attach the original .f3d file and the .dwg file here or you can email them to me and I can take a look at things for you.
Cheers,
