Hi friends,
Today I gave Fusion sketch a new run and quickly experienced some very limiting aspects.
For example snapping is still extremely under developed in Fusion.
You cannot snap a custom orientation widget to the grid
You cannot snap a circle drawing tool to excisting profiles.
You cannot snap 3 point acts onto excisting profiles.
In sketch mode only lines seem to be supportive of snapping to 3D geometry and onto edges.
Next semester I would like to utilize Fusion as a series alternative compared to Alias
but I find that with nearly many tools functions are missing or half implemented.
And in it's current state I simply cannot make the switch. The stability with Fusion is still a problem.
Just today it crashed with every document I had open. But that can be worked around.
Missing tools or functions however impact you much more significantly.
For example also the move and rotate scale option is very limited because again
Fusion does not have any decent snapping tool that applies to everyhing mesh surface solid curve and grid.
Here are to screencasts showing some of my frustration:
https://drive.google.com/file/d/0Byzv_NlyKp_2NVdhcHhyMjBzbFk/edit?usp=sharing
https://drive.google.com/file/d/0Byzv_NlyKp_2N3ZnT0JmOUVfTXc/edit?usp=sharing
I do not want to sound overly negative, I understand software development takes time.
But when you work on such an amazing workflow of T-Splines Design Timeline why dont
we have an untrim for surfaces or decent usable snapping?!
I posted some ideas in the idea station, can you maybe provide some insight into where Fusion is heading?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Thanks for posting these issues. I am trying to escalated them to get a resolution from development team, however I get some difficulties on reproducing the inferences issues when create 3 point arc and rectangle in first video. Could you share me the file to help addressing the issue? Thanks for your support and appreciate your help.
Here are screencasts showing you Fusion vs Rhino and Blender and I think it explains well why I think that the snapping tools
in Fusion are very under developed in their current state and need improvement if you want also designers to work with it.
Please let me know if this makes sense and answeres your questions.
Snapping:
https://drive.google.com/file/d/0Byzv_NlyKp_2VnJlakd0MWRRVVE/edit?usp=sharing
Align Move command in design time line:
https://drive.google.com/file/d/0Byzv_NlyKp_2czdzV2UxMWxUbWM/edit?usp=sharing
Something I forgot to mention, it makes no sense to add a move command into the time line when I used an align command.
The Timeline should feature me the align tool set when I edit the entry and not give me a move rotate dialog.
Claas Kuhnen
Hi cekuhnen,
Many thanks for your detailed videos to show your issues in snap, move and align. We also saw the item in Idea Station regarding Move and Snapping. All these are valuable feedback for product improvement and they are much appreciated!
Here are the summary of the issues as well as my comments:
Thanks for your clear and complete input. We are indebted to everyone who honestly provides these comments. I agree with your points and believe these comments will help us to prioritize these issues in the near future.
