I have a design with a modest number of components, all were created in Direct mode. I'm now trying to enter parametric mode- whenever I try to select that option Fusion crashes. Is there some point at which it becomes impossible to capture design history?
CER_93651148 and CER_93651182
Solved by jeff_strater. Go to Solution.
Ron,
Can you add the files or email to me? andrew.sears@autodesk.com
Andy
Sent a link to the file. After shelling one of the bodies, I had a crash when trying to use the split at parting line tool with the Split Body option. I used the Split Faces option, projected the edges to a sketch plane, and used that line to split the body, and it works perfectly. Perhaps this should be "project parting line to sketch plane".
Thanks Jeff. It's not really a problem for me, as I've become quite happy in Direct mode, but would like to explore parametric design in Fusion a bit. I can really see a use for both.
Hi Kingson,
I'm not actually sure exactly when the next update will be released, to be honest. Unfortunately, none of the items that you mention are part of this update. We are doing some cool things in the release, but, sadly, those are not some of them. These are all important requirements, but of them, Paste New and Make Independent are probably the highest priority ones. This is a pretty big project, and we are working on it, but we want to make sure that the quality is high enough for it to be useful. Thanks for your patience!
Jeff Strater (Fusion development)
Hi Jeff,
Thanks for your reply. At the present moment, I suggest the Parametric Users to Lights out on all unrelated bodies, components except the ones to be copied. Then use the Base Feature Mirror function to mirror the component. then dissolve the mirror function. I think it works sometimes but it is a good way in order not to stop recording mode. Well the Scale Problem is the worse. There is no way to work around this other than leaving the recording mode. Except we can first scale, export to a different f3d file with the percentage name, click back. Import the scaled file back and keep the parametric as root. Then the recording can be preserved. Just lots of logic. But If I kept the scaled f3d file in a folder inside the original one on my local archive drive, even at the DATA section of Cloud, that should be fine. We need that for ring size since we have to use a fully combined file to scale to different sizes. The Parametric version can make changes. In fact for rings that is what we should do.
Hi Ron, Fusion 360 crashes almost all the time when selecting to go back to the Old DM mode, or from DM mode to Parametric Mode. That happened to more complex files. Now I save a new version, save to Archive, then I close the file. I then reopen the file and perform the switching operations. It is better this way. With complex bodies I found that the Parametric Mode has really big performance issues. Maybe due to a large amount of TSpline Bodies, Sketches, etc.. that could not be deleted like in the DM mode. However I believe the Crashes from the TimeLine Mode to old DM mode had been successfully reproduced by one of their software engineers and they could be fixing it now. Let's hope for the best. I really wish that i can scale components without going into DM mode.
