Hi
Having autorecover issues with the application
I had one crash CER_81765171, after reopening the application I was given the option to open the autorecovered version of my file,
I opened this and was expecting to be able to perform a save-as so i could overwrite the current version which was last saved, no save as, so, plodded on with what I was doing in the autrecovered file,
same crash CER_81765555. reopened the application, but was not given the option to open auto recovered file this time as the file wasn't open any longer than about 5 minutes,
the only option I seem to have now is to open the previously saved version of my file which means I've lost work, is there any way of retrieving any autorecovered file now? And, is "Autoversioning" , new terminology for autosave that won't let me autoversion any less than every15 minutes. Can't find anything else resembling Autosave
Stephen
Solved by stevie.d. Go to Solution.
Just wondering if any of this is connected to the issue, since losing my work I'm just doing manual saves, got this some time after the last save
Then this one which is a server not found error I presume
My internet connection is fine
Hi Kevin, any updates please and do you know if it's connected to the issues I have been having while modeling,
Every time I attempted to select a face to edit using edit face command the apllication crashed, gave up after 4 times last night,
tried again this morning same issue, created a new design file to see if the problem was exclusive to the file that kept crashing same problem in new file with just an simple cube model. After restarting the application I am unable to access the new file at all, I've tried uninstalling the application including the cached files, reinstalled and the edit face issue seemed to go away, then this afternoon performance working on the model using edit faces became really sluggish and and then freezes, now I seem to be back where I was last and the application just crashes now .
CER_81824415
Forgive me if you have already said... But what are your commuter details? Type, memory and graphics card etc.
hi Kevin Thanks for your reply
Motherboard MSI-p67AGD65 i7-2600K@3.4GHZ 16GB Ram @1600mhz Nvidia GEForce GTX 280 @1GB, windows 7 64 bit let's know if you need any more info
Stephen
Turn of all effects CER_82748889.
Switch to DX9 and restart. CER_82749415
We could get to the bottom of the problem. This was bug in Edit Face and has been fixed (takes care of CERs mentioned in this thread). Thanks for reporting and apologies for the experience.
Anand Karyekar
Fusion 360 Development
yes, the fix has not been released yet. We will let you know when we do that.
Anand Karyekar
This fix should now be available with the latest update (Fusion 360 R1.2).
Let us know if the crashes you see are fixed and thanks for your support.
Anand Karyekar
Fusion360 Development
