Active Contributor
sanguish
Connection failed when attempting to import data files
208 Views, 5 Replies
05-06-2013 09:47 PM
I'm attempting to import .scad and .dwg files into Fusion. Drag them into place, no problem.
But I always get a 'connection failed' error. And no import.
Any idea how to fix this?
Scott
(failing that, anyone have a heart shape in Fusion? :-)
Please use plain text.
Board Manager
schneik
Re: Connection failed when attempting to import data files
05-07-2013 05:28 PM in reply to: sanguish
To start, we don't support scad files. The DWG will work. I am guessing that as you drag and drop files onto the dashboard the drop zone might be flashing?
If so it might take you a few tries to get the drop to take. I find that if I go the project list and drop directly on the project things work best.
We are making big changes to the dashboard and we are sorry the current dashboard is proving so difficult.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Member
boydwilkinson
06-26-2013 09:38 AM in reply to: sanguish
The dashboard, whose function seems to want to be that of a browser, lacks so many of the basic browser functions that every computer user is accustomed to (such as a simple forward/back function). The drag and drop import feature, although a nice idea, is so incredibly finicky that I often make 20 attempts to get a file to "take" without the incessant "connection failed" dialog box. There is no alternative to drag and drop, which requires re-sizing the otherwise full-screen Fusion 360 window in order to be able to import a file. Drag and drop (on the rare occasion that it works) would be a nice add-on, but not in place of a simple file browser that doesn't require reorganizing my desktop simply to perform an import.
For reference, I am importing both .dxf and .dwg files, and can't for the life of me determine any sort of feel for importing the simplest of files. Frustration levels on the rapid incline...
Board Manager
schneik
06-26-2013 11:11 AM in reply to: boydwilkinson
The version we delivered yesterday addresses many of these issues. It sounds as if you are still using beta?
Kevin Schneider
Active Member
boydwilkinson
06-26-2013 11:58 AM in reply to: schneik
Yes, *was* still on Beta, and now having difficulties uninstalling it. I followed the tutorial, but the folders listed (specifically the Autodesk and webdeploy folders) don't appear on my system (Mac OS x 10.8.4). I have trashed anything that resembles an Autodesk Fusion 360 file, and get the "Incompatible Versions Detected" error, wanting Fusion 360 and Sim 360 (I am unable to find this anywhere) uninstalled first. Help?
philip.s
06-26-2013 12:53 PM in reply to: boydwilkinson
Hi Boyd,
Just saw your post on this other Fusion 360 thread regarding access to the Library folder, and wanted to double check to make sure that you're good to go now. Please let us know if you need additional support on this one!
Philip Schmelzer
