Combine Feature with solid bodies
2 REPLIES 2
fpessolano
558 Views, 2 Replies
Hi there
I have built four solids and I am trying to combine them. See the attachment for what they are.
When i try to combine them into one body (so as to make a component out of it) the system seems to run fine but in the end only the biggest body and the horizontal cilinder are combined.
The other two elements will never be combined with the bigger body even if the are touching each other.
How can i solve this so as to treat it later as a component?
Thanks.
cheers
Francesco
2 REPLIES 2
Oceanconcepts
in reply to: fpessolano
If your goal is just to make these items into a component, convert one of the bodies to a component, then just drag the other bodies into the same component.  Components can contain multiple bodies, as well as other components, and will function as an assembly.
Ron
- Ron
Mostly Mac- currently M1 MacBook Pro
fpessolano
in reply to: Oceanconcepts
thanks!
w: Francesco Pessolano
e: francesco@fralke.com
wb: fralke.com
w=who // e=email // wb=website
