Hi
I can't install. It stalls on "Preparing" splash screen for long time, and then this message comes:
I'm behind a http proxy I should say. Does it honor those settings?
Regards
- BJörn
Solved by bjorn.syse. Go to Solution.
Solved by jessica.t. Go to Solution.
Hi Bjorn
1st must clean the “TEMP” folder that is have then try to install without the proxy, if you can. After that you can use the proxy, I’m using it now at home a proxy from school to log in and access to fusion 360.
Best regards from yours
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
Thanks for chiming in and helping out, RIshi!
Hi
What temp-folder do you mean?
Also, I have no possibility to install without a proxy.
Regards
- Björn
Hi Björn
To a new install or reinstall of the Fusion360, you must always delete these folders C:\Users\tmgxbs\AppData\Local\Autodesk\webdeploy\7015747d3c4b7a1968a4d7ed08e72861b54\Fusion C:\Users\tmgxbs\AppData\Local\Temp\7ZipSfx.000
The first folder name the large number may be different, as also the User name may be different.
Other solution is may be "Fix it", that is present for similar cases
http://support.microsoft.com/default.aspx?scid=kb;en-us;191143
hope some of this solves it
best regards
Rishi Vadher
Personal Page
Sorry, neither one of those two suggestions made any difference in my case.
Hi Bjorn!
Are you able to attach the log file referenced in your error message?
Hi Philip
Of course, actually I thought I did that in the first post but I forgot. Here comes:
Much appreciated!
I passed the error log onto our dev team earlier today for troubleshooting, and either myself or one of my colleagues will follow up with potential suggestions ASAP.
Apologies for the inconvenience and thanks for hanging in there!
Hi Bjorn,
To continue troubleshooting, we need to find out how your proxy is configured. What do you see in the Control Panel -> Network and Internet -> Internet Options -> Connections tab -> LAN settings?
Hi Philip
It's directed to use "an automatic configuration script". A .pac-script.
Best regards
- björn
Hi Bjorn,
Thanks for your patience as we researched your issue.
As a work around, you may reconfigure your browser to a static proxy. But be sure to do this with caution because if not done correctly, your use of other Autodesk websites could be affected.
Another solution would be to set a special "http_proxy" environment variable to point the proxy server which will allow the use of a static proxy server only for the streamer.
However; the streamer as packaged doesn't inherit system environment variables. Therefore, you must install with the “getfusion.bat” file in the attached zip (there are two files, you only launch one, but both need to be extracted).
Please let me know if these solutions work for you!
You're welcome! Glad to hear that worked for you, Bjorn!
We're here to help anyway we can to get our skilled users up and running
For the future, be sure to mark posts as solutions that resolve your issue so that others can find it if they are experiencing the same problem.
Thank you!
I have the same problem. Where do I get the getfusion.bat file? Thx, Ivan
Good to know, Ivan, thanks!
Attached is the zip file you need. One of our awesome developers just forwarded it to me
Please let me know if this resolves your issue.
Thanks!
Hi Ivan!
Thanks for the additional log information. Did the zip file resolve your issue? Please let me know if you need any additional assistance.
Thank you!
