So I copied and pasted an object I created, and when I go and edit one of them it changes the other as well, is there any way to stop that from happening, thanks for any help!
Solved by AndrewSears. Go to Solution.
You can copy both bodies and components so I assume you are talking about one of these when you mention "objects".
- Copy/paste of bodies does not maintain a relationship.
- Copy/paste of components with the same body in them will maintain the associative relationship. If this is what you are talking about then RMB on the component in the browser and choose "Make Independent". This will remove any associativity between the bodies.
Hope that helps. Let us know if you are getting something different or this did not answer your questions.
Andy
You will need to switch from History mode to model mode. This is currently blocked in History Mode.
If that is not helping, can you expand your browser and component 1 in another image?
Andy
I've been having the same issue, and I'd like to fix it. What exactly do you mean by history mode vs. model mode?
Try this (make a backup-copy file first).
Right click the top node in the browser -
