The new update seems to have broken a lot of things.
I'm running Windows 8.1. I'm running version 2.0.1193 of Fusion 360.
I can't:
What can I try to fix this? I can't get any work done.
Solved by innovatenate. Go to Solution.
Can you test signing out and signing back into Fusion 360?
Let me know if this helps or if the issue is ongoing.
I sent you an e-mail, directly.
I just wanted to add a note that performing a clean uninstall and re-install resolved the issue.
Jeff - let me know if you run into this again!
