Solid Edge has a cam mate that allows a flat surface to be actuated by an eliptica surface. Example would be a cam lobe pushing a cam follower up and down.
https://www.youtube.com/watch?v=s5n-2gb8yfM
I haven't figured out how to do this in fusion so I thought I'd see if it was possible before making a feature request.
This should be added to the IdeaStation as a request. If you don't mind, could you post a link back to this thread after you submit?
Done
http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/Cam-joint-mate/idi-p/5153880
