Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Calculating forces
7 REPLIES 7
Message 1 of 8
2575 Views, 7 Replies
Calculating forces
Hi, is it possible to calculate the forces required to work a lever in Autodesk 360?
7 REPLIES 7
Message 2 of 8
TheCADWhisperer
Is this what you are looking for
http://forums.autodesk.com/t5/Sim-360/bd-p/710
http://help.autodesk.com/view/ADSK360/ENU/
Is your question about Autodesk 360 or Fusion 360?
Message 3 of 8
innovatenate
Rigid Body Dynamic Simulation is not available in Fusion 360. You may submit a request to the Fusion 360 IdeaStation for future consideration.
http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/idb-p/125
For now, you may want to check out Force Effect:
https://chrome.google.com/webstore/detail/autodesk-forceeffect/ekbaidcchahkpedbhdenlmleimihkcim?hl=e...
Or... Force Effect Motion:
https://play.google.com/store/apps/details?id=com.autodesk.forceeffectmotion
https://itunes.apple.com/us/app/autodesk-forceeffect-motion/id512045820?mt=8
These two apps allow you to get quick force calculations for static and dynamic problems.
Inventor has a Dynamic Simulation Add-In that you also look at. I hope that helps.
Nathan Chandler
Principal Specialist
Message 4 of 8
in reply to: TheCADWhisperer
Thanks, I was hoping to not have to buy more products though.
Message 5 of 8
innovatenate
Force Effect Motion is a free app I believe.
Nathan Chandler
Message 6 of 8
maga_1
in reply to: innovatenate
Hi
Are there any updates in this topic?
For me it's a must have to calculate forces in a cad.
Force Effect Motion is not available anymore.
Is there an alternative?
Thanks for any answer
Martin
Message 7 of 8
TheCADWhisperer
in reply to: maga_1
Do you really need motion analysis?
If you are a student you can get Autodesk Inventor Professional with Dynamic Simulation for free.
But perhaps all you need is to apply a Prescribed Displacement and the retrieve the Reaction Force.
Can you File>Export and then Attach you *.f3d file here?
Message 8 of 8
maga_1
Yes, I need motion analysis. Friction, acceleration, gravity, torque and so on.
What very well fits my needs is:
https://www.ptc.com/en/products/cad/creo/parametric/mechanism-dynamics-option
unfortunately I have no more access to this software.
I guess Autodesk Inventor Professional with Dynamic Simulation is quite the same, but I'm not anymore student.
Any other recommendation?
I really hope Fusion 360 will include this kind of analysis in future.
