I created a coil first. Then I used the tool 'Plane Along Path' to create a plane at the inner path of the coil.
But if I click OK the plane jumps to the other path as you can see in the following video:
http://screencast.com/t/IjgLHubj141
I wanted to attach the F3D file but after clicking 'Post' it says:
>The contents of the attachment doesn't match its file type?!?
Solved by joseph.shi. Go to Solution.
Hi thburn:
Thanks for reporting this issue.
This issue has been addressed and will be fixed soon.
