I'm trying to de-clutter the browser by using the Dissolve command on some of the long list of features, like Extrude 374, that I don't care about editing. This was a suggestion from AU.
But when I use this command, a "ghost" image of the body associated with the feature appears in the drawing, and I can't get rid of it. It's still there even if I Undo the Dissolve command. Even if I turn off visibility for everything in the drawing.
This behavior is consistent and reproduceable, and feels like a bug. I note that closing and re-opening the document seems to clear up the ghost images.
Solved by schneik-adsk. Go to Solution.
