I've had a serious issue tonight and last night with the 3D navigation cube in the upper fight hand corner randomly disappearing.
Restarting doesn't make it come back. I'm kind of lost without it.
Is there a fix (this is on the latest public Mac version)
Thank you to post the problem!
Would you like to try to "Reset to default layout"?
Hope it can fix the problem.
I wonder if it related to the problems I experienced in this thread: http://forums.autodesk.com/t5/Help-and-Support/Odd-failure-mode-lost-all-manipulators-components-dis...
In my case, turning off the grid visibility seems to have helped.
Thanks Ron, I think they are similar problems, thanks your work around.
The developer is working on the root problem now.
