Is the below model similar as yours?
First step, get the sketch profile of the tube.
Above is the common steps to add the protrusions, also you can try to use the Rib command instead of the Extrude command after you got the sketch profile you want.
If you right click on the active sketch in the browser you should be able to Slice Sketch.
